I keep locking myself out of a switch on CML when configuring line con
BruteForce
I'm trying to do something simple and I keep logging myself out. Here are the commands I enter in this order.
>username cisco privilege 15 secret 5 cisco
>aaa new-model
>aaa authentication login default local
>aaa authorization exec default local if-authenticated
>line con 0
>login authentication default
At this point I can log completely out, but then I get an authentication failed when trying to log back in. I KNOW I'm not fat fingering the password or adding an extra space after it. Also when I type "sh run | s line", the command I added under line con 0 does not appear. exec-timeout 0 0 will appear though.
@BruteForce
When using the secret 5 option in the username command, you should enter the hashed password directly. The hashed password is the encrypted form of the actual password...
Best regards
10 Replies 10
You use local database user/password or radius?
Local database
BruteForce
Well, it looks like it's because I'm specifying secret 5 instead of secret. If I use secret 5, I'm I supposed to enter the hashed password you'd see on a "sh run" command?
@BruteForce
Best regards
Use password only without
Secret or secret 5
And check
MHM
You can access but you  can not go to conf t ?
If this case here ?
M02@rt37
@BruteForce
Log first
Do: debug aaa authentication and terminal monitor
Open a new ssh session and see debug.
Best regards
not end yet
Please try below
Then show running
Share running here
Waiting your reply
MHM
Hello, the issue was "Secret 5" rather than "Secret". I didn't attempt to input the password in the running config, but I removed "secret 5" and was able to log in just fine.
You are learning so you must not skip any info.
You config is correct
As I know we can add unencrypted passwords in config
But when we show run it appear as encrypt
Then we use what appear in config to access device.
MHM
