Multiple VLAN access problems between switch and firewall
cemrecanaltinel
One of my customers has the following situation: In the connections between the Switch and the ASA firewall, all VLANs are not connected to the firewall with a single trunk port, separate access VLAN ports are configured for each VLAN and each port is connected to the firewall with a physical cable. In the current situation. There are no free ports left on the firewall, and a separate interface is used for each VLAN. They want me to add a new VLAN from the switch to the firewall without interrupting the existing traffic. I need to add another VLAN to one of the existing access ports. For example, my interface configuration for VLAN 20 on the switch is;
interface GigabitEthernet1/0/2
description "Uplink to ASA 5508-X Firewall Port Mgmt"
switchport access vlan 20
 the configuration of the firewall port opposite it;        interface GigabitEthernet1/2
description tyu Interface
nameif tyu
security-level 100
ip address 172.26.20.250 255.255.255.0
They want the existing connections not to be interrupted. Now my question is; If I add the switchport trunk native vlan 30 command to add gig1/0/2 vlan 30 on the switch;
 switchport access vlan 20,        switchport trunk native 30        and vlan 30 in the firewall with subinterface
interface GigabitEthernet1/2.30
vlan 30
nameif art
security-level 0
ip address 172.26.30.250 255.255.255.0.        In this way, will the clients and servers using both vlan 20 and vlan 30 continue to work without interrupting the traffic? Or should I trunk the switchingig1/0/2 port and configure vlan 20 and vlan 30 as allowed vlan? Could you help me ?Can I use both access vlan and native trunk vlan on one port?
3 Accepted Solutions
When you move from access port to Trunk port the configuration chagnes.
you will have only switchport trunk and allowed VLAN 20,30 and you can have native vlan command 30
BB
The native VLAN thing tells the switch what to do with any frames that arrive on the port without a tag. For example when you define a native VLAN on a trunk, you tell the port that any untagged frames arriving on that port should be switched to that specific VLAN, without really caring about what VLAN it may have actually come from.
So if you were to also define a access VLAN on the port, you would have a conflict. When an untagged frame arrives, should the port move the frame to the trunk native VLAN, or the access native VLAN? It would have no way to tell. Therefore, you can't do it.
Richard Pidcock
Level 6
Level 6
You won't get through these changes without at least a minor disruption when you reconfigure one of the interfaces from an access port to a trunk port.  I think your best option is to get your changes prepared and then get an agreed upon maintenance window where you can make the changes and tolerate the brief disruption.  I agree with @balaji.bandi , establish your trunk between the FW and switch and you will future proof yourself for future requirements.
Richard W. Pidcock
10 Replies 10
You use two link between sw and asa
One is access for mgmt
Other is trunk that allows some vlan But must not be allow mgmt vlan(vlan20) in trunk
That config is work
But you should care about the routing in SW.
Thanks for it,it make sense but I am curious about that question; Is there an explanation of how I can config both access and trunk native vlan  at the same time on a switch interface?        switchport access vlan 20,        switchport trunk native 30, like this is possible?
Just to clarify the issue
You have two interface in FW and two interface in sw'
One interface connect like trunk
Other interface connect like access port (from sw side)
If that correct
If above correct I think I get why you are confused.
In this case fw can not send two untag frame through two link
You need to make in FW interface connect to access port of sw router port not vlan port.
Router port dont care about the tag.
MHM
I have 2 connections between fw and switch and both have access connections. I do not have a trunk connection and I need to trunk one of my access connections. My problem is, can I do this without any interruption, but I understand that this is not possible
It possible' why not?
How you config your FW?
Share config
MHM
balaji.bandi
You sure going to have small network intruption, when you making this changes.
If the downtime agreed for 1 or 2 VLAN, suggest to bring port-channel between Firewall and Switch, so you can use sub-interface and also furture expansion, also you can consolidate exiting VLAN in to new port-channel free other ports.
if that is not the case you want to use single port for now.
then you need to convert Switch port in to Trunk and use SVI on the Switch side.
on the firewall, configure sub-interface for different VLAN with dot1q trunking.
example :
https://www.cisco.com/c/en/us/td/docs/security/asa/asa96/asdm76/general/asdm-76-general-config/interface-vlan.pdf
BB
thanks for your suggestion.I will take your advice  but what I'm really curious about is this;Is it possible , Is there an explanation of how I can config both access and trunk native vlan  at the same time on a switch interface?        switchport access vlan 20,        switchport trunk native 30, like this is possible?
BB
Richard Pidcock
Level 6
Level 6
Richard W. Pidcock
