Showing results forĀ
Search instead forĀ
Did you mean:Ā
Ibgp Peer establishment question
mahesh18
Level 6
Level 6
Hi all,
Here is info
We have two routers R1 and R2 and they are in same  AS  1.
they are in IBGP.
Here is R2 config
router bgp 1
neighbor 1.1.1.1 remote-as 1
neighbor 1.1.1.1 update-source loopback 0
Can someone please explain we why we use the command --neighbor 1.1.1.1 update-source loopback 0 and what does this mean.
Many thanks
mahesh
2 Accepted Solutions
On R1 and R2, you configure loopback IP. The loopback of R1 must be reachable by R2 and R2, by R1. On R1, you peer to R2 Lo0 with a source of R1 Lo0 and on R2, you peer with R1 Lo0 with a source of R2 Lo0
It means the BGP relationship we're having with 1.1.1.1 will be sourced from Lo0 (1.1.1.1 is the Loopback address of the other router).
Regards.
Alain.
6 Replies 6
dominic.caron
Level 5
Level 5
You will peer with the other router using the logical interface loopback 0. Peering with a logical interface is usualy a good thing. If you peer using a physical interface and it fail, you will lose your peering. If you use a logical interface, your router might still be reachable using another path.
Hi dominic,
thanks for reply it means we have to apply IP address of loopback interface ?
or we can say that R1  routers  loopback0 interface has IP  address of 1.1.1.1?
regards
mahesh
Hi Dominic ,
Many thanks for detailed explanation.
regards
mahesh
Regards.
Alain.
--R1--
int lo0
ip add 1.1.1.1 255.255.255.255
router bgp 1
nei 2.2.2.2 remo 1
nei 2.2.2.2 update lo 0
--R2--
int lo0
ip add 2.2.2.2 255.255.255.255
router bgp 1
nei 1.1.1.1 remo 1
nei 1.1.1.1 update lo 0
