IBM Blade switches not accepting an IP address
millmatt
When I give the FA0 this command:
interface FastEthernet0
ip address 172.24.0.240 255.255.255.192
no ip route-cache
I get a response that because it is not part of a stack or has IP routing turned on, it will not let me reconfigure the IP address of the interface. How am I supposed to configure an IP address on an interface if I do not turn on IP routing? Never seen this issue on any other model of switch, not sure if it is a blade architecture thing or not. Thanks for the insight.
Matt
Reza Sharifi
Matt,
Is this 3110 switch? If yes, it is a layer-2 switch by default.  If you want to assign a management IP address, you need to configure an SVI interface.
inter vlan xx
ip address xx.xx.xx.xx
Reza
