IDENTIFYING A SWITCH ROOT BRIDGE
jmureyani001
Community Member
Hi guys please help me. Which Cisco IOS command do you enter on a switch to enable you to see which switch is currently the root bridge when there are so many switches and spanning tree is enabled?
hardiklodhia
Level 5
Level 5
hi,
show spanning-tree detail / show spanning-tree summary can be used to know abt root bridge for that spantree valn instance.
rgrds,
guruprasadr
Level 11
Level 11
Hi, [ PLS RATE if HELPS ]
"show spanning-tree root"
!!Display the STP Root information for all VLAN's configured on a switch.
Other commands for your referenece:
show spannning-tree summary totals
!!Display STP summary information for all VLANs configured on a switch
!!Display detailed STP information for all VLANs configured on a Switch
show spanning-tree vlan vlan-id bridge
!!Display STP bridge information for a specified VLAN
PLS RATE if HELPS
Best Regards,
Guru Prasad R
