Idk what I’m doing wrong. The static PCs won’t ping the DHCP PCs.
OpenDoors
This is the instructions. I created the PT top left to bottom to right following the instructions.
Physical Configuration:
Create the following network in Packet Tracer version 8:
    • 2 - Switches(2960), connected together using Ethernet Cables via port G0/2
      • Label as S_East and S_West
    • 4 - Computers using DHCP, 2 attached to each switch
      • On S_East label the Computers PC_East 1 and PC_East 2
      • On S_West label the Computers PC_West 1 and PC_West 2
    • 1 - Router(2901), Labeled R_ROAS, connected to S_West using Ethernet Cable via port Gi0/1(switch and router)
    • 1 - Switch(2960), Labeled S_North, connected to R_ROAS using Ethernet Cable via port Gi0/1(switch)
    • 2 - Computers using static IP attached to S_North
      • Label the Computers PC_North 1 (fa0/11) with IP 192.168.4.11, and PC_North 2 (fa0/22) with IP 192.168.4.22
    • 1 – Switch(2960), Labeled S_South, connected to S_North with Layer 2 Etherchannel using 4 fast ethernet lines
General Configuration:
Establish the following where necessary:
    • DHCP (on R_ROAS) for network using 192.168.1.0/24
      • Exclude .1-.10 from the DHCP scope so they aren't handed out
      • DNS server ip is 192.168.1.5
      • Domain name is ACME.com
    • Statically assign IP's to all Infrastructure devices - use first available IP for each network on R_ROAS
    • On R_ROAS - Gi0/1 will use 192.168.1.0/24 network, Gi0/0 will use 192.168.4.0/24 network
I BELIEVE I DID THE ABOVE BUT THE STATIC PCS ON THE RIGHT WONT PING THE PCS TO THE LEFT PASSED THE ROUTER.
THESE ARE PING RESULTS:
North PCs ping each other
North PCs ping Router
Router pings itself
Router does not ping any East or West devices
Router pings both North devices
I personally believe it’s the dhcp confit or the default gateway? I’m just lost at this point. Please help.
4 Accepted Solutions
post the zipped Packet Tracer project (.pkt) file...
Ok will do. I need at least 30 mins as I’m not home rn.
the problem was that none of your PCs on the left were getting an IP address at all, because of a typo in the excluded range on the router:
ip dhcp excluded-address 192.168.1.1 192.169.1.49
After changing this to:
ip dhcp excluded-address 192.168.1.1 192.168.1.49
all PCs get an IP address, and everything has full end-to-end connectivity.
Attached the revised, working file.
I feel so defeated. I spent all night trying to find the error and it was 1 number.
8 Replies 8
VDavidCC
Hello, could you please paste the running-config of R_ROAS and the output of the Show ip dhcp binding command
The sh ip dhcp binding does not work on my router. I also tried others that involve dhcp and still no results.
Building configuration...
Current configuration : 1010 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname R_ROAS
ip dhcp pool ACME
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 192.168.1.5
ip cef
no ipv6 cef
username cisco privilege 15 secret 5 $1$mERr$9cTjUIEqNGurQiFU.ZeCi1
license udi pid CISCO2901/K9 sn FTX152487AI-
ip domain-name ACME.com
spanning-tree mode pvst
interface GigabitEthernet0/0
ip address 192.168.4.1 255.255.255.0
ip helper-address 192.168.1.0
duplex auto
speed auto
interface GigabitEthernet0/1
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router rip
ip default-gateway 192.168.1.1
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
R_ROAS#sh ip dhcp
R_ROAS#sh ip dhcp binding
IP address Client-ID/ Lease expiration Type
Hardware address
R_ROAS#
