IE-3000-4TC with IEM-3000-4PC
Mikheil Melia
Hello
We've used ie-3000 series for the first time, and tried to make system consisting of
IE-3000-4TC+ 2x IEM-3000-4PC work, assigned ip to IE-3000-4TC, entered its interface from web and cisco enwork assistand but weren't able to make
IEM-3000-4PC work. And weren't abel to find a configuration page to activate conenction between this components.
IEM-3000-4PC untis are powered by PWR-IE65W-PC-AC that's led indicated DC pwoer is ok, but all leds on
IEM-3000-4PC are off, we tried t oconnect to network throgh it's port by laptopn, the led was orange all the time and network was not accessible
Richard Primm
Hi Mikheil,
If you are trying to get the IEM-3000-4PC to work, make sure that you are on at least 15.0(2)EY1.  This is probably the most common "gotcha" I come across.  Hope that helps.
-Lp
hi Richard
Thansk for reply, you're absolutely corret. The switch has 12.x IOS and we're waiting for demanded one from our supplier
