07-14-2019 05:12 AM
Greetings to all,
Do I have to order a seperate power supply for Does IE-3000-8TC ?
Kindly share minimum requirements for powering on this switch.
Is it a must to add power supply ?
07-14-2019 06:13 AM
Hello!
Do You want use two power supply?
and what IE-3000 modules you use?
also you want AC power or DC?
07-14-2019 06:49 AM
Just the IE-3000-8TC. One power supply is enough. But onsite there is only 120AV source available.
So what is the best power option.
As per datasheet and installation, we can connect power from a separate DC power source on network cabinet directly to the power connectors on switch and its not necessary to order seperate power supply PWR-IE50W-AC.
Details shown in below link. Pls check below link and confirm if its ok.
We may add 8T expansion modules later.
07-14-2019 07:02 AM
Yes, you can use existing DC power source.
What DC power available on your cabinet ? (Voltage and available current)
07-15-2019 08:15 PM
