ie 3000 external memory card
dhanie0415
How do you access/read the 64MB external flash memory card? I can access/read the internal flash but not the 64MB card. I've tried DIR disk0: and DIR slot 0: does anyone know what the command is?
nkarpysh
Hello, what is your SUP/IOS versions?
Basically PCMCIA card should be on dosk/slot. You can check where it is if plugged in by "show file system". It will show you all storages within your sup/standby. Those designated by disk# or slot# is the COMPACT flash drives. Bootflash or sup-bootflash are the disks installed on the MSFC?SUP physically.
Hope this helps,
Nik
HTH,
Niko
