Cisco 2610 Router - what speed is the built in Ethernet port?
greggsmithjr
I have a 2610 router. How can I tell if the built-in ethernet port is only a 10BASE-T or if it's a 10/100 port?  Is there a "Show" command to give me this information or did it only come one way?  I have found conflicting information on this :-(  If it's only 10BASE-T, can I upgrade it to 10/100?
Gregg
206-795-0597
If you no longer have any questions, can you please mark this thread as "Answered"?
8 Replies 8
nkarpysh
Hi Gregg,
If router is just 2610 then port is 10 MB only and you can't upgrade that. If 2610XM - then it is 10/100.
http://www.cisco.com/en/US/partner/docs/routers/access/2600/hardware/installation/guide/2600ch1.html
Nik
HTH,
Niko
Leo Laohoo
Look at the back of use the command "sh ip int brief".  If you see "Ethernet" only, then it's 10 Mbps.  If you see "FastEthernet" then it's 10/100 Mbps.
greggsmithjr
Thanks, guys ... appreciate it!
Hey ... where do I mark it as "answered"???
I think you just did Gregg.  Thanks.
Cool ... thanks. Did you see my question on the other forum? Any thoughts
would be appreciated.
I did.  I have posted my response.
