02-10-2025 03:30 PM
Can anyone confirm which type of PoE the IE-3300-8P2S network switch can support? Is it 802.3bt Type 4?
02-10-2025 03:40 PM
High-density industrial Power over Ethernet (PoE) |
● Supports
◦ up to 24x PoE/PoE+ ports or 4x 802.3bt type 4 ports (with 2.5G expansion module) with the all GE PoE enabled base [Power budget - 360W] ◦ up to 24x PoE/PoE+ ports or 8x "802.3bt type 3" ports or 4x "802.3bt type 4" ports with the 10G, PoE enabled system [Power budget – 480Watts] |
02-10-2025 04:16 PM
Thank you!! Are any of the ports capable of Type 4 PoE then, but you can just use 4 of them to not exceed the power budget? Or are certain ones only capable of Type 4 and they would be labelled on the switch?
02-10-2025 04:32 PM
Or do you need a certain expansion module that has the Type 4 ports?
02-10-2025 05:25 PM
Expantion module is required
The Cisco Catalyst IE3300 Rugged Series delivers power over Ethernet (PoE) over up to 24 ports (with expansion module) to easily connect and power end devices such as IP cameras, phones, wireless access points, sensors, and more"
02-10-2025 09:26 PM
@jmarczuk
The Cisco IE-3300-8P2S switch supports PoE and PoE+ but does not support 802.3bt Type 4 (which provides up to 90W per port). The maximum PoE power budget for this switch is 360W with expansion modules. If you need 802.3bt Type 4 support, you may want to consider the IE-3300-8U2X model, which provides 4PPoE (802.3bt Type 4) support with up to 60W per port
Link : https://www.cisco.com/c/en/us/products/switches/catalyst-ie3300-rugged-series/datasheet-listing.html
Thanks!
