IE-3300-8T2X-E SFP Compatibility
chriswj88
The catalyst-ie3300-rugged-series-ds.pdf data sheet for the does not explicitly state that a SFP-10G-T-X SFP module is compatible with the IE-3300-8T2X-E switch.
Is there a reason why a SFP-10G-T-X SFP module wouldn't work with a IE-3300-8T2X-E switch?
M02@rt37
Hello @chriswj88
SFP-10G-T-X should be compatible with your IE-3300 model.
Refer here: https://tmgmatrix.cisco.com/?npid=3961
Best regards
M02@rt37
Hello @chriswj88
Best regards
I was unaware of the https://tmgmatrix.cisco.com/ page for checking optics device compatibility.  This will be very useful in the future.
Thanks.
You're so welcome @chriswj88
Best regards
