IE 3300 TACACS connection not working with code 16.12.03
r1127hyduk
Level 4
Level 4
Seeking IE 3300 TACACS sample configuration - for code 16.12.03
Question - Are there any new requirements for TACACS configuration with this code version noted above (16.12.03)?  We have zero issues with devices running 15.2.7 IOS
Current configuration for new IE 3000 models are not working for TACACS 'access' with ISE server 2.7.
All tacacs commands are accepted in the IE 3300 code version.  Sample notations listed below....
AAA
aaa authentication login default local group tacacs+
aaa authorization exec default local group tacacs+
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 0 default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 2 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
IP domain-name whatever
ip tacacs source-interface Vlan100
tacacs-server host x.x.x.x
tacacs-server key cannotconnect
Solution works with all previous switch versions except new IE3300-8ts2 models that have code version 16.12.03.
ISE configuration has tac key and name / ip address of new devices. 500 plus devices work fine.  New IE 3300 devices do not sync with TACACS server.  Looking for any suggestions for device/IOS version noted here.  Thanks for reviews in advance!
2 Accepted Solutions
Leo Laohoo
Please do not use 16.12.X.
Use 17.3.X but avoid 16.12.X.
could be related to 'tacacs-server' being a deprecated command. Try the new syntax:
tacacs server
address ipv4 x.x.x.x
key X
6 Replies 6
balaji.bandi
if you looking to use Group of TACACS servers  then Local try below :
aaa authentication login default group tacacs+ local
BB
Leo Laohoo
Hello Leo,
Do you recommend a specific 17.3.x version for the IE3300?
we have working environment 16.12.X version they are ok (again depends on requirement) . if you looking to upgrade, Look for  17.3.3 or 4 should be good.
BB
@r1127hyduk wrote:
Hello Leo,
17.3.4 or 17.3.5.
Our fleet is on 17.3.4 and we have not encountered any problems.
tacacs server
key X
