IE 4000 Switch Heat Issues
mfox2302
Having issues with IE 4000 switches running hot, nearing operating limit/shutting down.  Switches running at 70 degrees Celsius. Switch is in sealed non vented outdoor enclosure, but not directly exposed to elements. Questions, has anyone come across similar issue?  Did installing a fan/cooling unit solve the issue?   Would just venting the cabinet be sufficient.
balaji.bandi
as per the datasheet below : ( if that is going beyond mentioned, cooling will help).
BB
