IE3300 Rugged Switch SD Card Auto Sync
cgwest
I am trying to find out if the IE3300 has the same auto sync feature that is present in the IE 2000. I have looked through the System Management Configuration Guide for the IE3x00 Rugged and the Configuration Guide for the IE 2000, and it seems like the 2000 has a much more involved sync command and a section on Auto Sync. Does the IE3300 not have auto sync capability? Is there a way to add it?
I am new to Cisco products, and I am trying to get up to speed with the most common switches used by my company. Thank you in advance for any help!
0 Replies 0
