IGMP CONFIGURATION between client and serveur
Hi ,
I have a problems for see the streeming in a tv that not connect in same network with server.I have a server tangram that send the streeming.It's directly connect with a switch catalyste 4500 that i configure a igmp server in vlan 10.I have a other batiment that have a other vlan for IPTV.In this batiments i can't see the streming.But in de same vlan with server i can see the streming.
Configuration in switch 4500:
ip igmp snooping querier
ip igmp snooping VLAN 10
Configuration in switch 2960 :
ip igmp snooping
ip igmp snooping VLAN 100
Can you please help me is very critical
17 Replies 17
Okk Thank you we do like this and i coming back to you.
Hi Jon,
I want inform you you that the streaming is still not working aften activation of PIM.
Did you capture the route table outputs I asked for ?
Couple of basic things to check -
1) have you enabled PIM on every L3 interface in the path ie.
if you do a tracroute from server to client and also client to server you need all the hops enabled with PIM.
2) have you ensured the TTL of the multicast stream is greater than the number of L3 hops.
Jon
