IGMP Querier configuration
g.ska
Frequent Visitor
Frequent Visitor
Hi everybody,
I have a question about the configuration of IGMP querier. I have a small setup with 3 cascaded switches and a querier configured on the "Main switch" (where SVI are configured). I would like to know if the IP address of the querier need to be configured on all switches (with the command:  ip igmp snooping querier address xxx) or if access switch will automatically learn the querier ip address?
does someone can send me the minimum required for IGMP querier configuration? (No need multicast-routing and pim configuration. Just querier)
Many thanks,
Greg.
Reza Sharifi
You can but there is no need to configure querier statically.  The hosts will join and leave dynamically.
Not sure what type of switch you are using but here is the config guide for the 3750 series.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/12-2_52_se/configuration/guide/3750scg/swigmp.html#wp1025709
Actually, the Core switch is a Catalyst 6500 series and we have 2 x 2960X connnected behind.  But the setup can change and the core switch can be a Catalyst 3850 or 4500X. Is there any differences between the models for this kind of configuration?
Greg.
The command/config could be different because for example 6500 run IOS but 4500x runs IOS-XE.  So, you would have to look at the spesific config guide for that platform.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I think I recall, on multicast featured L3 devices, you enable PIM on the interface to enable the IGMP querier.
I think I also recall, some L2 switches provide an IGMP querier, that you can enable, when there's no multicast GW device.
