IGMP snooping/multicast rate-limit on 6500 switch RP-best practice?
will
Level 3
Level 3
hi, I am _not_ doing multicast routing on 6500 platform, but would like to enable IGMP snooping. I am currently facilitating snooping by using an ASA firewall configured for just IGMP (no PIM, no inter-vlan mrouting). Apparently, the 6509 needs a Vlan interface with IGMP querier/mrouter enabled to facilitate setup of IGMP snooping in a vlan. So I have this configured and it appears to work with ASA. I am seeing very low PPS count for IGMP snooping, but am concerned about protecting the switch from any form of multicast "broadcast storms":
my_6509#sh ip igmp snooping rate-limit
Max IGMP messages incoming rate : Not configured
Vlan    Incoming IGMP rate (in pps)
258     3
Can anyone direct me toward a IGMP multicast rate-limiting & tweaks best practice guidelines for the 6500 with a VS-S720-10G supervisor? I have two 6509 in a VSS pair configuration.
thx in advance,
Will
PS, here is sample ASA interface configuration if anyone is interested in making this work in a similar fashion. In my case, I wanted to _NOT_ create vlan interfaces on the 6500, as it seems like somewhat of a security violation, when everything should flow through ASA for L3 "routing":
!turn of mrouting on all interfaces:
Interface vlan1
  no mfib forwarding
Interface vlan2
  no mfib forwarding
!enable mcast routing
multicast-routing
!enable just igmp on the interface i need (vlan1 by default), disable PIM on all interfaces:
interface vlan2
  no igmp
interface vlan1
  no pim
interface vlan2
  no pim
0 Replies 0
