Multicast and WS-SUP32-GE-3B
bmiguez
I have a Catalyst 6500_SUP32 with the following modules:
6500_SUP32#show module
Mod Ports Card Type                              Model              Serial No.
  1   48  48-port 10/100/1000 RJ45 EtherModule   WS-X6148A-GE-TX    aaaaaaaaaaa
  5    9  Supervisor Engine 32 8GE (Active)      WS-SUP32-GE-3B     bbbbbbbbbbb
  6    9  Supervisor Engine 32 8GE (Hot)         WS-SUP32-GE-3B     ccccccccccc
Mod  Sub-Module                  Model              Serial       Hw     Status
  5  Policy Feature Card 3       WS-F6K-PFC3B       ddddddddddd  2.3    Ok
  5  Cat6k MSFC 2A daughterboard WS-F6K-MSFC2A      eeeeeeeeeee  4.0    Ok
  6  Policy Feature Card 3       WS-F6K-PFC3B       fffffffffff  2.3    Ok
  6  Cat6k MSFC 2A daughterboard WS-F6K-MSFC2A      ggggggggggg  4.0    Ok
- When I try to send a multicast stream through 2 ports configured on Vlan 200 (these ports are the only that are configured on this vlan), it doesn´t works.The configuration of ports is:
interface GigabitEthernet6/1
switchport
switchport access vlan 200
switchport mode access
load-interval 30
speed nonegotiate
end
interface GigabitEthernet6/2
switchport
load-interval 30
speed nonegotiate
end
6500_SUP32#sh int gi6/1
GigabitEthernet6/1 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 001c.5834.acdc (bia 001c.5834.acdc)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 1/255, rxload 104/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is LH
  input flow-control is off, output flow-control is on
  Clock mode is auto
  Last input never, output 00:00:15, output hang never
  Last clearing of "show interface" counters 3d17h
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 410198000 bits/sec, 37648 packets/sec
  30 second output rate 0 bits/sec, 0 packets/sec
     29848173 packets input, 40652574233 bytes, 0 no buffer
     Received 29847515 broadcasts (29847515 multicasts)
     89 runts, 0 giants, 0 throttles
     858 input errors, 746 CRC, 659 frame, 0 overrun, 0 ignored
     0 watchdog, 0 multicast, 0 pause input
     5159 packets output, 6642310 bytes, 0 underruns
6500_SUP32#sh int gi6/2
GigabitEthernet6/2 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 001c.5834.acdd (bia 001c.5834.acdd)
     reliability 255/255, txload 1/255, rxload 132/255
  Clock mode is auto
  Last input never, output 00:00:38, output hang never
  30 second input rate 518714000 bits/sec, 47608 packets/sec
     23136224 packets input, 31508399163 bytes, 0 no buffer
     Received 23133286 broadcasts (23133286 multicasts)
     628 runts, 0 giants, 0 throttles
     4519 input errors, 3569 CRC, 2942 frame, 0 overrun, 0 ignored
     3076 packets output, 3830662 bytes, 0 underruns
- When I try to send the same multicast stream between 2 ports (ports giga 2/13 and giga 2/14) with exactly the same configuration on a 6500 with the following modules:
6500_SUP720#show module
  1   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       hhhhhhhhhhh
  2   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       iiiiiiiiiii
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       jjjjjjjjjjj
it works fine.
- The same for a 3750, it works without the need of adding new configuration commands.
- The questions are:
1. Why this does not work on WS-SUP32-GE-3B? (Architecture of this module???)
2. Do I need to configure some feature to get it works? I will configure the "ip igmp snooping querier" in the next test, but, Do I need add some more command?
Many thanks in advance.
Benito M.
9 Replies 9
Amit Singh
Hi Benito,
Could please paste the output of "show ip igmp snooping vlan 200" from the SUP 32 side.
If IGMP snooping or PIM is not enabled on the vlan, you might see this behaviour. You can either enable " ip pim sparse-dense mode" under the vlan 200 interface or just configure the " ip IGMP snooping querier " on the switch to work this out. You dont need any other config command as such.
Cheers,
-amit singh
Hi Amit,
Thank you very much for your fast answer.
I have no configured an interface vlan 200 (SVI), I only have a vlan 200 (level 2).
The commands are:
6500_SUP32#show ip igmp snooping vlan ?
% Unrecognized command
6500_SUP32#show ip igmp snooping ?
  explicit-tracking  IGMPv3 Explicit tracking database
  filter             IGMP Filtering Information
  mrouter            Show routers beyond a port
  rate-limit         IGMP messages incoming rate
  statistics         IGMPv3 channel statistics
6500_SUP32#show ip igmp snooping expl
6500_SUP32#show ip igmp snooping explicit-tracking ?
  detail  Counter details
  vlan    Vlan keyword
  |       Output modifiers
6500_SUP32#show ip igmp snooping explicit-tracking vlan ?
  <1-4094>  Vlan ID to examine
6500_SUP32#show ip igmp snooping explicit-tracking vlan 200
Source/Group                    Interface       Reporter        Filter_mode
6500_SUP32#show ip igmp snooping filter ?
  interface  IGMP filter interface information
6500_SUP32#show ip igmp snooping filter interface ?
  GigabitEthernet  GigabitEthernet IEEE 802.3z
  Port-channel     Ethernet Channel of interfaces
  Vlan             Catalyst Vlans
6500_SUP32#show ip igmp snooping filter interface vlan ?
  <1-4094>  Vlan interface number
6500_SUP32#show ip igmp snooping filter interface vlan 200 ?
  Vlan             Catalyst Vlans
6500_SUP32#show ip igmp snooping statis
6500_SUP32#show ip igmp snooping statistics ?
  interface  Interface specific IGMPv3 channel statistics
  |          Output modifiers
  |          Output modifiers
6500_SUP32#show ip igmp snooping statistics interface ?
  Async              Async interface
  Auto-Template      Auto-Template interface
  CTunnel            CTunnel interface
  Dialer             Dialer interface
  EsconPhy           ESCON interface
  Filter             Filter interface
  Filtergroup        Filter Group interface
  LongReachEthernet  Long-Reach Ethernet interface
  Loopback           Loopback interface
  MFR                Multilink Frame Relay bundle interface
  Multilink          Multilink-group interface
  Null               Null interface
  Portgroup          Portgroup interface
  Pos-channel        POS Channel of interfaces
  SYSCLOCK           Telecom-Bus Clock Controller
  Tunnel             Tunnel interface
  Vif                PGM Multicast Host interface
  Virtual-Template   Virtual Template interface
  Virtual-TokenRing  Virtual TokenRing
  Vlan               Catalyst Vlans
  fcpa               Fiber Channel
  voaBypassIn        VOA-Bypass-In interface
  voaBypassOut       VOA-Bypass-Out interface
  voaFilterIn        VOA-Filter-In interface
  voaFilterOut       VOA-Filter-Out interface
  voaIn              VOA-In interface
  voaOut             VOA-Out interface
  |                  Output modifiers
6500_SUP32#show ip igmp snooping statistics interface vlan ?
6500_SUP32#show ip igmp snooping statistics interface vlan 200 ?
Please, let me know if you need the output of some other command.
Benito.
Hi Benoit,
Sorry, I thought that you had the SVI configured for the vlan. If its a pure L2 network, then " IGMP querier" the solution for you.
Please see the problem  and the solution that you are facing below.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008059a9df.shtml
Cheers,
-amit singh
Hi Amit,
Thank you very much for your answer.
I think that "igmp snooping querier" must be enabled in Global configuration mode, but in this device is not possible:
6500_SUP32(config)#ip igmp ?
  immediate-leave  Leave groups immediately without sending last member query, use for one host network only
  limit            IGMP limit
  snooping         Global IGMP Snooping enable for Catalyst Vlans
  ssm-map          SSM mapping commands
  vrf              Select VPN Routing/Forwarding instance
6500_SUP32(config)#ip igmp snooping ?
  cgmp                  configure CGMP option
  l2-entry-limit        limit on the l2 entry that can be installed by IGMP snooping
  limit                 Configure IGMP Snooping limits
  source-only-learning  source-only gce entries
Neither "igmp snooping querier" nor "static mrouter port" can be enabled, so, I think I must configure a SVI for vlan 200, asign an IP and configure "ip pim sparse-dense-mode" on it...do you agree?
Moreover, these features are needed when we have 2 or more switches, but I only have one switch, I don´t understand because of this...(Architecture of Sup32???)
Thank you very much.
Benito.
Benoit,
Here is what I want you to try :
1. Try enabling IGMP snooping globally. ip igmp snooping
2.  Create a VLAN interface for vlan 200 and then configure IGMP snooping querier under that. Except for the global enable command, all IGMP snooping commands are supported only on VLAN interfaces.You need to configure an IP address for this vlan, it doesnot work without the IP address.
3. If it doesnot work then try configuring the IP PIM sprse-dense mode under the SVI.
4. You can also try configuring static multicast receive if the above two steps doesnot work.
Please see the link below to understand the IGMP snooping on the Cat6500.
HTH,
-amit singh
Hi Amit,
In the second option, must I configure an IP on the same Network that the source address of the multicast flow?
Benito.
Yes, IP address on the VLAN 200 interface in your case.
-as
Hi Amit,
I have just done the tests.
1. I first did enable "ip igmp snooping": it didn´t work.
2. I did configure a SVI for vlan 200 with IP and mask. The configuration was:
interface Vlan200
ip address x.x.x.x x.x.x.x
end
but it didn´t work.
3. I did configure:
interface Vlan200
ip igmp snooping mrouter interface GigabitEthernet6/1
ip igmp snooping mrouter interface GigabitEthernet6/2
end
With this configuration, it works fine.
I don´t understand why we must configure an "mrouter" (I understand in case of ports located on different switches...), because those ports are in the same switch and in the same module... Could it be due to the Architecture of the SUP32?
Thank you very much for your help.
Benito.
you need to configure this odd L3 interface due to architecture of 6500 switch and sup module. seems like a defect to me, but that's what TAC told me. There are workaround, such as enable IGMP on firewall interface if firewall has an L3 interface on this vlan. or enable IGMP on connected router. this will facilitate the IGMP snooping. here is a document that discuss IGMP among two catalyst switches. basically, i think of 6500 switchports as all min-switches in regard to setup of IGMP snooping,. in other words, you need to adhere to this document, thinking catalyst has a "switch" on each port in its fabric.
