IGMP Snooping on 3560
Zarahelll
Good day to you all
I need a little help on how to configure igmp snooping on a 3560.
I have a pure L2 switching network and 2 hosts on the same vlan that want to communicate a protocol between each other using multicast packets.
I wanted to configure ip snooping only on this vlan and create a multicast group limited to only these 2 host ir order to make sure that the multicast traffic is only between both of them.
Since both are sender and receiver I´m not quite sure on how to configure this. In theory I also need to set an IP Multicast Address on the switch to where the hosts will send their multicast packets.
This is basically the network:
HOST_A---|SWITCH_A|==|SWITCH_B|---HOST_B
Can anyone help me with the configurations required to make it work?
Best regards
11 Replies 11
Raju Sekharan
by default igmp snooping should be on
if it is not on, use the below command in global mode to enable it
ip igmp snooping
Also configure on of the switch as igmp snooping querier becasue you don't have any multicast-routing
ip igmp snooping querier
Reference link:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_52_se/configuration/guide/swigmp.html#wp1193337
Thank you
Raju
rajs2
Thank you for your feedback
I just have one doubt. What if I want to use an unregistered multicast address? I don´t want the hosts to send multicast packets through 224.0.0.1 address...I want to use any other address (for instance 239.10.10.1). Do I have to configure it on the switch?
My current configs are:
ip igmp profile 1
    permit
    range 239.10.10.1 239.10.10.1
interface GigabitEthernet1/20
switchport access vlan 50
switchport mode access
spanning-tree portfast
spanning-tree bpduguard enable
no ip igmp snooping tcn flood
ip igmp filter 1
end
Will this suffice?
The hosts can send multicast to any group. There is no need of additional config on the switch.
however for the igmp snooping querier to work, there should be an IP address configured on the switch
Raju
My current config:
ip igmp snooping querier address 192.10.40.5
ip igmp profile 1
    permit
ip igmp filter 1
end
The querier address IP address is part of the host's network range.
The config looks good
Thank you
Raju
rajs2
Thank you very much for your help. Just one final question: I´ve tried disabling igmp snooping globally, since I just want it to work on 1 specific vlan, but when I do so I'm not able to set a querier address. It returns an error saying it requires for igmp snooping to be set globally.
Since you mentioned I need ip igmp snooping querier for my L2 Multicast solution to work, is there any way to set it up without having the igmp snooping defined globally?
remove the querier and disable igmp snooping globally
After that configure igmp snooping only for VLAN
ip igmp snooping vlan
After that configure the querier
Thank you
Raju
Doesn´t work.
I´ve enabled it on vlan 50:
SWA# show ip igmp snooping
Global IGMP Snooping configuration:
IGMP snooping                : Disabled
IGMPv3 snooping              : Disabled
Report suppression           : Disabled
TCN solicit query            : Disabled
TCN flood query count        : 2
Robustness variable          : 2
Last member query count      : 2
Last member query interval   : 1000
Vlan 10:
IGMPv2 immediate leave              : Disabled
Multicast router learning mode      : pim-dvmrp
Vlan 50:
IGMP snooping                       : Enabled
but when I check for the igmp querier I have no output:
SWA#show ip igmp snooping querier
Vlan      IP Address               IGMP Version   Port
SWA#
after that did you try configuring igmp snooping querier for that Vlan
Raju
Yes. This is my current config:
ip igmp snooping vlan 50 querier address 192.168.40.5
no ip igmp snooping
ip igmp profile 1
    permit
ip igmp filter 1
end
But when I perform the 'show ip igmp snooping querier' command I get no output:
SWA#
Can you try confguring  " ip igmp snooping querier" under interface vlan 50
Raju
