05-05-2017 12:58 PM - edited 03-08-2019 10:28 AM
I have two layer two switches, lets call the switch X and switch Y. On these two switches I have two VLANS defined 41 and 42. I have setup one of the gigabit ports on each switch to be a trunk port and the two switches and communicating successfully. It has come to my attention that both VLAN 41 and 42 will have a few multicast devices on them which has me thinking about IGMP snooping on both VLANS. From the reading I have done it looks like IGMP snooping is globally enabled and also enabled per VLAN as you create them. What I would like to do is have switch X be the VLAN 41 querier and have switch Y be the VLAN 42 querier. I have an IP address assigned to VLAN 41 on switch X and an IP address assigned to VLAN 42 on Switch Y.What I have tried so far has not worked successfully. I have posted the config from switch X and switch Y below. Can anyone offer me some knowledge with how to complete this probably very simple task? Thanks in advance.
Switch X:
Using 2341 out of 65536 bytes
! Last configuration change at 17:21:22 UTC Sat Mar 6 1993
version 15.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
ptp mode e2etransparent
Switch#terminal length 0
Switch#show config
version 15.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
ip igmp snooping querier
crypto pki trustpoint TP-self-signed-1768263040
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1768263040
revocation-check none
rsakeypair TP-self-signed-1768263040
crypto pki certificate chain TP-self-signed-1768263040
certificate self-signed 01 nvram:IOS-Self-Sig#1.cer
no mac authentication
mac authentication table version 0
spanning-tree mode rapid-pvst
alarm profile defaultPort
alarm not-operating
syslog not-operating
notifies not-operating
vlan configuration 1,40,43
no ip igmp snooping
vlan internal allocation policy ascending
interface FastEthernet1/1
switchport access vlan 42
interface FastEthernet1/2
interface FastEthernet1/3
interface FastEthernet1/4
interface FastEthernet1/5
interface FastEthernet1/6
interface FastEthernet1/7
switchport access vlan 41
interface FastEthernet1/8
interface FastEthernet2/1
interface FastEthernet2/2
interface FastEthernet2/3
interface FastEthernet2/4
interface FastEthernet2/5
interface FastEthernet2/6
interface FastEthernet2/7
switchport mode trunk
interface FastEthernet2/8
interface FastEthernet3/1
switchport access vlan 40
interface FastEthernet3/2
interface FastEthernet3/3
interface FastEthernet3/4
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface Vlan1
no ip address
interface Vlan41
no ip address
interface Vlan42
ip address 192.168.42.73 255.255.255.0
ip http server
ip http secure-server
line con 0
line vty 0 4
login
line vty 5 15
login
end
Switch Y:
Using 2305 out of 65536 bytes
! Last configuration change at 00:08:53 UTC Mon Mar 1 1993
version 15.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
Switch#show config
version 15.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
ip igmp snooping querier address 192.168.41.28
crypto pki trustpoint TP-self-signed-1768256128
subject-name cn=IOS-Self-Signed-Certificate-1768256128
rsakeypair TP-self-signed-1768256128
crypto pki certificate chain TP-self-signed-1768256128
alarm not-operating
no ip igmp snooping
vlan configuration 42
switchport mode access
interface Vlan1
no ip address
interface Vlan41
ip address 192.168.41.28 255.255.255.0
interface Vlan42
no ip address
ip http server
line con 0
line vty 0 4
login
line vty 5 15
login
end
