Showing results forĀ
Search instead forĀ
Did you mean:Ā
im can use 2 vlans of 2 different interfaces in switch on mode trunk ?
almir fiorio
Dear Friends
Im have two different interfaces
switch is connected in router by gi0/3 .
but im have another Fa0/2 in router with vlan 38 and the switch is in trunk with router..
im want to use one vlan of Fa0/2 and another vla of Gi0/3 on the switch connected by trunk
im can put some ports in this switch on vlan 38 and others ports  in vlan 50 ????
See :
interface GigabitEthernet0/3
duplex auto
speed auto
media-type rj45
negotiation auto
no keepalive
interface GigabitEthernet0/3.50
encapsulation dot1Q 50
ip address 10.135.50.1 255.255.255.0
ip access-group 100 in
ip helper-address 10.132.5.81
interface FastEthernet0/2
bandwidth 100000
duplex auto
speed auto
media-type rj45
negotiation auto
no keepalive
interface FastEthernet0/2.38
ip address 10.132.38.1 255.255.255.0
ip helper-address 10.132.38.81
srikanth ath
Level 4
Level 4
Trunk ports are usually carry Vlan traffic to the Connected port.
Short answer for this Yes u Can
it depends on ur Requirement to specify what Vlans should be carried from the Trunk port. If you are allowing all the vlans to trunk port it carries all Vlan 38, Vlan 50 and all the specified vlans on your switch.
#switchport mode trunk
#switchport trunk allowed vlan all
If u specify selected vlans to be carried from the trunk it do carry only those vlans with the tags away from the trunk port. like with the simple example to configure trunk port in carrying vlans from 50 to 80.
switch# switchport mode trunk
#switchport allowed vlan 50-80
Hope i answered you, do reply back and give rating if it is satisfying you.
Srikanth
