Showing results forĀ
Search instead forĀ
Did you mean:Ā
implement qos on a cisco 3560 switch
gscalia01
Please help!!!
I have a 3560-48 switch running Cisco IOS Software, C3560 Software (C3560-ADVIPSERVICESK9-M), Version 12.2(44)SE3 and i need to implement basic QOS commands to the fast Ethernet interfaces as well as the gig  interfaces and Also I need to create port channels on the switch and need what the port channel syntax are as well for that particular IOS version?
I have only read only access and i can't see what the QOS and Port channels syntax should be for that IOS version.
Any help would be greatly appreciated.
Thanks in advance.
Jack
Hi Jack,
Following is the configuration guide for 3560 QoS there you can aloso find other information you need about commands.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_44_se/configuration/guide/swqos.html
You will need admin level to configure the switch.
*Please rate helpful answers.
Best regards,
Alex
Thanks for the quick response.
-- Sent from my Palm Pre on Verizon Wireless
I am happy to help you.
Please rate helpful posts.
Best regards,
Alex
