Implication if I omit 'switchport trunk encap'
news2010a
Level 3
Level 3
Imagine my environment is all Cisco switches. If my intention is to assure that dot1q is my encapsulation protocol when on trunking mode, is it necessary to do:
fa0/1
switchport mode trunk
switchport trunk encap dot1q <===
switchport trunk allow vlan (...)
In my environment the line 'switchport trunk encap dot1q' is not present in switches. I just want to confirm that is not necessary and DTP would negotiate encapsulation dot1q by default, always? From reading the documentation so far, it is not clear to me if certain platforms could pick ISL as a default, in case 'trunk encapsulation dot1q' is not specified.
Leo Laohoo
Some Layer 2 switches, such as the 2950 and 2960 series switches, support 802.1Q only therefore the commands "switchport trunk encapsulation dot1q" will not be accepted.
Hope this helps.
6 Replies 6
i.va
Level 3
Level 3
DTP is disabled by specifying either "switchport mode access" or "switchport mode trunk". "switchport mode dynamic auto" is default and not shown in the running config...this enables DTP.
If the switch offers the switchport trunk encap dot1q command, you should use it to specify dot1q (ISL is default). If this command is not present, the switch only supports dot1q, thus making the command unnecessary( since dot1q is the only option).
hth
So if I do:
1)
or:
2)
switchport nonegotiate
In both scenaros above DTP would be disabled. Configurations 1) and 2) are the same then?
I stand corrected...the actual forwarding of DTP frames is turned off by the switchport nonegotiate command.
If you statically configure permanent trunking mode with switchport mode trunk DTP is still active and negotiates to convert the link to a trunk.
Here is the info straight from Cisco (see Usage Guidelines):
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_sea/command/reference/cli3.html#wp1948171
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_sea/command/reference/cli3.html#wp1989134
Leo Laohoo
Hope this helps.
Edison Ortiz
As Leo pointed out, the reason you don't see the 'switchport trunk encapsulation dot1q' command in some switches is due to the lack of ISL support on those switchports.
If the switchport has only one trunking option, it is implied that is using dot1q protocol.
If the switchport supported ISL and dot1q, you will be unable to set the switchport 'mode trunk'.
A error message such as the one below would come up:
Switch(config-if)#sw mo tr
Command rejected: An interface whose trunk encapsulation is "Auto" can not be configured to "trunk" mode.
Switch(config-if)#
You can also find out the switchport capabilities on trunking support with the following command:
Switch#sh int f0/1 cap
FastEthernet0/1
Model: WS-C3560-48TS
Type: 10/100BaseTX
Speed: 10,100,auto
Duplex: half,full,auto
Trunk encap. type: 802.1Q,ISL
Trunk mode: on,off,desirable,nonegotiate
Channel: yes
Broadcast suppression: percentage(0-100)
Flowcontrol: rx-(off,on,desired),tx-(none)
Fast Start: yes
QoS scheduling: rx-(not configurable on per port basis),tx-(4q2t)
CoS rewrite: yes
ToS rewrite: yes
UDLD: yes
Inline power: no
SPAN: source/destination
PortSecure: yes
Dot1x: yes
HTH,
__
Edison.
Leo Laohoo
Thanks for the rating.
