Implicit Rule :Flow is denied by configured rule
ASA Version 9.1(7)
interface Ethernet0/0
 nameif outside
 security-level 0
 ip address 182.71.13.74 255.255.255.248
interface Ethernet0/1
 nameif CDE
 security-level 100
 ip address 10.153.164.1 255.255.255.0
interface Ethernet0/2
 nameif thirdparty
 security-level 100
 ip address 172.26.7.1 255.255.255.0
interface Ethernet0/3
 nameif DMZ
 security-level 0
 ip address 172.26.6.1 255.255.255.0
interface Management0/0
 management-only
 nameif management
 security-level 100
With Above Interface I am not able to Access CDE from thirdparty
Trace Result as below
ciscoasa# packet-tracer input thirdparty tcp 172.26.6.100
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Additional Information:
in 10.153.164.0 255.255.255.0 CDE
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group thirdparty_acl in interface thirdparty
access-list thirdparty_acl extended permit ip any any
Phase: 3
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-interface: thirdparty
input-status: up
input-line-status: up
output-interface: CDE
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
10 Replies 10
sachintambat
Bcoz both interface are on same security level
Add below command
same-security-traffic permit inter-interface
To allow the access
Sachin
Dear Sachin it has been done but still it is not working .
Also please find the attachment of configuration .
cde (10.153.164.0/24 to DMZ 172.26.6.0/24) packet trace pass is going ok
cde to 3rd party interface access is allowing
3rd party to cde interface access is not allowing (need port 53 access ).
dmz to cde port 443 not allowing (due to implicit acl)
Please help us to resolve.
why this rule is inactive.
access-list thirdparty_access_in extended permit tcp any4 any4 eq domain inactive
can you remove inactive and check.
Use only
and check
Is it works for you?
After adding above command
Dear Sachin
No
The above command is not  helping.
ASA Version 9.1(7)
 nameif outside
 security-level 0
 nameif CDE
 security-level 100
 nameif thirdparty
 security-level 100
 nameif DMZ
 security-level 0
Now
Form CDE to DMZ network is working.
From CDE to Thirdparty network is working.
We need
From DMZ to CDE port 53
And From Trirdparty to CDE port 53 and 443
For ->From DMZ to CDE port 53
Add below command
access-list DMZ extended permit tcp host x.x.x.x host x.x.x.x eq 53
access-list DMZ extended permit udp host x.x.x.x host x.x.x.x eq 53
For -> And From Trirdparty to CDE port 53 and 443
remove->access-list thirdparty_access_in extended permit tcp any4 any4 eq domain inactive
using
no access-list thirdparty_access_in extended permit tcp any4 any4 eq domain inactive
Add-> access-list thirdparty_access_in extended permit tcp any4 any4 eq domain
access-list thirdparty_access_in extended permit udp any4 any4 eq domain
