Impossible to access CLI through USB console cable..
d.taborda
Community Member
I am facing a problem that is driving me mad right now.. I have 2 switches 2960S and one 2921 router, and it is currently impossible for me to access the CLI at all.
I am using a USB console cable that came with the switches/router, and I downloaded the USB driver from Cisco's website.
I am on Windows 7 64bits so I installed the Vista 64 bits version of the driver.
I am using putty to connect to the equipements, and all i got is an error saying impossible de open connection (check COM ports). I already checked the COM ports that shows in the device manager to connect to the right port, I get only errors not even a black screen or something.
I tried all of the following :
- Uninstalled/installed the USB driver 3.1 many times (even tried the previous version 3.0)
- Tried to connect again and again to the COM ports displayed in the device manager (COM19 or COM20 in general after all my installations)
- Tried manually to change the COM ports from 1 to 10+)
- Tried to change speed from 100 to 19200 and 115200, and used the default parameters (no flow, no parity, 8 bits, 9600 bauds and 1 stop bit)
- I tried to reset the switch holding the "MODE" button for 7 seconds.
- I changed the console cable for another one
- I tried Putty, Hyperterminal, Peraterm
All the above I tried on the 2 switches and the router, same result = connection error.
The devices are all new so it is the first configuration...
I really don't understand what is wrong..
Please help if you have an idea.
0 Replies 0
