Impulse Safe Connect implementation
Peter Marshall
I keep getting locked-out of my switch when I make the following configuration changes per Impulse Safe Connect. I'm wondering if anyone else has dealt with this issue. The supplied text files show a typical switch configuration in the 'test.switch.before' document, and the 'script' document are the changes. I can call TAC to find the offending command, but I'm posting here to see if anyone has been able to work through this. If I find the solution from either Impulse support or TAC, I'll post here.
Georg Pauwen
I am pretty sure the problem is with the AAA. I have tested your script on a switch, and I need to add:
aaa authentication login default group radius local
and under the vty lines:
login authentication default
for the configuration in the script to work....
Georg Pauwen
Georg, this worked.
For anyone else testing a similar scenario, it took my a good 30 seconds to log into my WS-C2960X-48LPS-L, running 15.2(2)E7 C2960X-UNIVERSALK9-M, since it's off the network (cannot reach the RADIUS server).
Thanks!
PS:
"aaa authentication login default local group radius" instead of
"aaa authentication login default group radius local" eliminates that 30-second delay
