HI,
I can't find a discussion that matches my problem closely enough for the fix to work.
I've got a 3 x 3850 stack with 10 x 2960 access switches connected.. The VTP looks good on all of them, but I keep getting incomplete entries in the arp table. Attaching config in case it's needed but for the moment I was hoping it was a quick, easy oversight on my part. I have the same config on another site and don't have the issue. Thanks,
