02-14-2012 07:46 AM - edited 03-07-2019 04:55 AM
Need some advice:
We have a small isolated lab environment network, i.e. only machines connected to the network are visible, no external connections.
We currently have a WS-C2950T-48-SI and as the number of machines connected will be increasing soon we will need more than the 48 ports provided by the 2950 switch.
I see that the max ports is on most Cisco switches is 48, so thinking that we should stack another switch on the network in order to add more ports.
Can we stack a 2950 with the recommended replacement, the WS-C2960-48TT-L. If so, is there any documentation on how to connect the two?
The goal would be to make a stack that would appear as a single IP for control purposes.
We currently configure the existing 2950 switch into multiple VLANS, so will need to maintain that capability to create VLANS across the 2 switches.
Thanks in advance for any help.
02-22-2012 05:37 AM
Leo,
I think I owe some clarifications.
Then why bother stacking? Why don't you just give each of your switches a management IP address, put them all in one VLAN and be done? Ensure your uplinks are all in a trunk.
The software we run will require the available switch-ports to be configured into multiple VLANs. So a single VLAN will not meet my requirements.
But stacking 16 switches is a very, very, very, very bad design
Will only be stacking/clustering 2 switches.
02-22-2012 07:14 AM
I think that the 2960-S switch is an excellent choice, even if you do not buy the stacking modules at this stage. The
48TS-L model has 48 ports and 4 separate uplink ports (not shared). It also has a separate isolated management port which we like.
If you are buying several switches then I would buy the modules and stack up to four in one location. This creates the appearance of one switch and it makes management and performance considerably better.
If you have two or more switches I would disagree with Edison and recommend that you use VTP (properly configured) and nominate two switches as servers with a shared domain name.
Daniel
02-22-2012 01:35 PM
My deepest apologies ... but I still don't see where "switch clustering" fits in. Let me get this straight (pass the coffee), each ports connected to your software requires multiple VLANs, for example, 300, 400, 500?
If this is the case then configure the ports of your choice into a 802.1q Trunk.
Let me see ... With a 2960, you'll just need to enter the command "switchport mode trunk" and this will enable the port to use multiple VLANs per port. You can also "specify" which VLANs you want using the optional command of "switchport trunk allowed vlan 300-400,500".
Is this what you are looking for?
02-23-2012 04:47 AM
No problem, I am equally confused I think.I'll try to explain. This isnot a normal network setup at all.
In a nutshell our "systems" consist of a mix of ~ 55 PCs and Sun servers. Our new requirement is that each system shall be capable of being separated into up to 3 standalone systems, e.g. machines 1,2,3,4,5..20 would be on vlan 300, machines 21-35 would be on vlan 400, and the rest on vlan 500.
The goal is to be able to run up to 3 "systems" simultaneously using the same hardware. Since the software running on all 3 systems will be identical. The 3 vlans would need to be isolated so that they appear to be 3 separate networks.
I realize this is a special case, but those are the requirements for our training systems.
02-23-2012 10:15 AM
Randy
As I understand it, this is a completely normal use case for VLANs. You need to add your second switch and connect it via at least one cable. An etherchannel would make sense to get more throughput. You do not need to do stacking or clustering.
You will need to build the same VLANs on each switch and trunk them all over the link. This is normal deployment. You can do this manually or using VTP.
Important - you will need to consider how these VLANs will talk to each other, if necessary. You will need some separate routing device that has all the VLANs trunked to it.
Daniel
02-23-2012 01:18 PM
Alright Randy. I get what you are trying to do. But I believe switch "clustering" is out of the question.
1. If you have two (or more) switches then you may have to configure 802.1Q Trunking.
2. Next you need a Layer 3 device to do routing or the three VLANs will not talk to each other.
3. Since you have two switches you may (optionally) configure etherchannel (just as Daniel has posted).
Wait a second ... Did you say 2960??? Ok, load the 12.2(55)SE3, SE4 or SE5 and you'll be able to do limited routing.
With only three VLANs, it could save you some money buying a router.
02-24-2012 04:57 AM
Gentlemen,
OK, a few more questions/clarifications to your comments.
MY boss wnats the cleanest install / configuration possible. For each site, if I buy 2 Catalyst 2960 (and ditch the 2950), upgrade the IOS to the version Leo suggests, and given the following clarifications, what is the bottom line equipment I would need to acommplish my requirement of 3 independent VLANs and support for up to 55 PCs/Suns attached.
Was planning on using the Gbit port on the 2960.
You will need to consider how these VLANs will talk to each other, if necessary.
Based on our requirements they will not need to talk to each other - i.e., machines on VLAN 300 will not be able to see machines on VLAN 400 or 500.
The machines on each VLAN need to be isolated from each other, see above.
limited routing.
Yes, the 2960 is what Cisco recommends updating to on thier web-site.
I really appreciate your guys' comments and suggestions !
02-24-2012 09:49 AM
The cleanest configuration possible, in my opinion, is to buy two new C2960S 48 port switches with stacking modules and connect them in a stack. This will effectively one 96 port switch with a single management interface. You can connect to it using the management ethernet port and not even enter the lab network from your desk.
You will create three VLANs in additon to VLAN 1, which I would not use for any of the ports.
You will not need an additional linking cable or etherchannel. You will not need to use any of the switch ports for linking.
Then you will not need any routing device. Bear in mind that any firewall/gateway you have on the lab network will need to be replicated on the new VLANs. You should not need the routing features of the C2960S.
Daniel
02-25-2012 02:45 PM
I agree with Daniel.
If you have the funds, get the 2960S and the stacking modules. This is one LESS configuration headache when you stack them together PLUS when you configure the two units, you only do your configuration in ONE.
This is not rocket-scientist. If each of the three VLANs are not meant to talk to each other then you don't need routing. Just configure each port to their corresponding VLANs so each VLAN will only talk to their own VLAN.
02-27-2012 06:53 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
So, on a cluster of 2 switches, the max switching speed between the 2 switches would be the speed of the port that I connect the 2 switches together (e.g., one of the G-bit ports). So traffic from devices connected to a port on switch A (100 Mbps) to a device on switch B (also connected on the 100Mbps port), would effectovely be 100Mbps (max of 1000Gbps).
Yes and no. Many manageable switches support bundling multiple ports to increase aggregate bandwidth. Even when this isn't done, the situation often is not dire since you still need to consider the bandwidth on uplinks from a chassis or stacked switches. In other words, links to/from your location often bottleneck before links at the location.
The only thing that is making me cling to the clustering setup is cost. I need to buy 16 switches (will connect 2 per site). Expansion above 2 switches per site is very -very unlikely. Also, all network traffic will be local to the 2 switches which will be installed in a isolated lab environment with all machines are on the same subnet.
The major "disadvantage" of your extra "logical" switches would be the need to assign twice as many switch management IPs. (NB: this assumes 2 IPs per location rather than just 1 IP per location.)
BTW, what you've described as desiring to do was routinely done before clustering or switch stack technology was available.
I will suggest going with the 2960-S, so that if needed in the future, we can stack them, but will probably use clustering for now. I think buying the stack modules in addition to the switches would be cost prohibitive for our project.
Stacking often offers nice features beyond just conservation of management IPs, although 2960 might not be as nice as Stackwise(+) available in the various 3750 series.
02-27-2012 05:06 AM
Well, based on the comments and suggestions from this thread, I will go with two 2960S switches. Initially I wont be able to afford the stacking modules, but may upgrade at a later time.
I will trunk the two ports together via the gigabit port and deal with extra config (changes in the config are not very likely after the intial setup).
leo and Dan, thanks for all your paitence and good advice - I now have a better understanding of the problem and how to go about addressing it.
