Industrial Switches IE 1000 Command line
arun panengal
Not able to get the the normal commands like config terminal and all to do the switch configuration through CLI.
Attaching the list of command available in the switches.
not sure if you are in a position to get a different firmware image, but I have been looking at the thread linked below, and it appears that some versions actually do have a CLI:
https://community.cisco.com/t5/switching/ie-1000/td-p/3335060
marce1000
 - Ref : https://www.cisco.com/c/en/us/products/collateral/switches/industrial-ethernet-1000-series-switches/datasheet-c78-737277.html
 >....   Manageability: Web GUI interface, and diagnostics and analysis options through Simple Network Management Protocol (SNMP) and syslog
 M.
Thanks @marce1000 .And there is no way to configure the switches through CLI. If possible , help me with command list .
