information on tx-drops-queue on switches
vancampdax
I've just installed new server switches ( CAT4506-E with SUP6-E modeule ) but I still have drops in some queues.
I need to know what's causing these drops, so I need to know the description for the tx-drops-queue on switches.
All drops occur in yx-drops-queue-8
Ganesh Hariharan
Check out the attached document for on dynamic buffer limiting with refernce to tx-drops-queue
http://www.google.co.in/url?sa=t&source=web&ct=res&cd=4&ved=0CBIQFjAD&url=http%3A%2F%2Fwww.cenic.net%2Foperations%2Fdocumentation%2FCENIC-QoS0604%2FCat4500%2520QOS%2520CENIC.ppt&ei=jUvhS-voJtC1rAe-0oXlAg&usg=AFQjCNEJ-YKbrIH4pvCNZmHa1HyuP8rQHQ
Hope to help !!
Ganesh.H
Remember to rate the helpful post
Thank you for the informaion.
I've reviewed it and have now a better knowledge of the queues but....
I understand the 4 QOS queues, but what about the other queues 5 - 8. I can't find any information on these queues.
Jon Marshall
Can you post the output from the switch that is showing you the drops in the queue you mentioned ?
Jon
