Inner Vlan Comunication problems
RoutingMouse
HI, i have decide to ask because i have no more ideas. I come here to ask for your help.
im having the fallowing issues:
Vlan x used for clients on a location:
  • Can receive DHCP in all zones of the distribution network
  • In some zones you get DHCP but cant ping GW and CAN browse and ping other networks
  • In other zones you can ping GW ( no problem  here)
I did sniff some packs but i did not detect any Man in The Middle attack, no mac or arp floods etc
Vlan y used for Switches management vlan and some servers:
  • Nagios: can ping all segments of the network
  • Cant ping some Switches on the same vlan y (those sw that it cannot ping are the same access sw that use vlan x for users)
I have checked cam table, it all seams to be OK , no incomplete entries or wrong MAC address
I have also check ARP table
Im also having the message popup i have search this notification and everybody says that it means an native vlan mismatch or encapsulation configuration, but my sw have the same native vlan on all sides (Vlan0060). Don't rly know why is Vlan1 being mention its not used as native.
%SPANTREE-2-BLOCK_PVID_PEER: Blocking GigabitEthernet0/25 on VLAN0001. Inconsistent peer vlan.
%SPANTREE-2-BLOCK_PVID_LOCAL: Blocking GigabitEthernet0/25 on VLAN0060. Inconsistent local vlan
Now for the structure
We have the core in our Data center and from there is distributed to the sectors of my work place
Core= 3750 -3560
Access= CE500
CoreSw>Data center SW >>Servers
Location1 Core
Access Sw    Acces Sw   Acess Sw
                                         Access Sw
Like that(but its abigger scnario), there is no redundancy in the location 1 core so its hard for a SPT loop to form. its all downstream
Any thing else you woul like to ask. Please Ask.
A little Mouse
***********************Wont let me post reply so ill update from here**********************************
sure. posting the hole interface config and swicthport status
Distribution side
interface GigabitEthernet1/0/1
switchport trunk native vlan 60
switchport mode trunk
spanning-tree guard loop
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
nterface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
description To_SW_FUN_PRI_DR09
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
this goes the same for all interfaces
sh interfaces gigabitEthernet 1/0/1 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 60 (Interswitches)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Access Side
To G1/0/1
description To distribution g1/0/1
ip arp inspection trust
srr-queue bandwidth share 10 10 45 35
srr-queue bandwidth shape  10  0  0  0
udld port aggressive
mls qos trust cos
macro description cisco-switch
spanning-tree link-type point-to-point
ip dhcp snooping trust
TO G1/0/2
mls qos trust cos
TO G1/0/3
mls qos trust cos
TO G1/0/4
mls qos trust cos
TO G1/0/5
mls qos trust cos
TO G1/0/6
mls qos trust cos
TO G1/0/8
mls qos trust cos
TO G1/0/9
mls qos trust cos
TO G1/0/10
mls qos trust cos
TO G1/0/11
mls qos trust cos
And this goes the same for the access sw
Switchport: Enabled
Voice VLAN: none
Protected: false
rfalconer.sffcu
Level 3
Level 3
Can you post the trunk configurations on each switch?
