input and output rate on fastethernet in cisco router and switches
hi ,
traffic coming inside to interface is inbound and traffic leaving the interface is outbound .
similarly in CAT5 cable which pair is used for input rate and which pair is used for output rate , when we force speed 100 Mbps and duplex full
kindly brief me thank you .
Giuseppe Larosa
Hello Saintoskumar,
for pinout = cable details see
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a00801f5d9e.shtml#rj45
to be noted that two types of Rj-45 ports exist one type "NIC" and one "switch" they can be connected with a straight cable because the "switch" port receives on the wires where "NIC" port sends and viceversa.
Hope to help
Giuseppe
