Input Discard on Nexus Data Broker
SulthanGhazali
Hello everyone,
Anyone has same issue like Input Discard counting on Physical Loopback Nexus Data Broker. I'm follow Design ERSPAN Termination for Nexus Data Broker from this documentation.
https://www.cisco.com/c/en/us/td/docs/dcn/nexus-data-broker/310x/use-case/erspan-termination.html
And also i'm follow to avoid oversubscription scenario like this, because input discard can counting if at topology have bottleneck or micro-burst as unexpected traffic.
https://www.cisco.com/c/en/us/support/docs/switches/nexus-9000-series-switches/217340-understand-the-tahusd-buffer-threshold-e.html
But untill now input discard still counting
NDB-Switch# show interface ethernet 1/11 | include discard
0 input with dribble 0 input discard
0 lost carrier 0 no carrier 0 babble 2240 output discard
NDB-Switch#show interface ethernet 1/13 | include discard
0 lost carrier 0 no carrier 0 babble 575 output discard
module-1# show hardware internal tah buffer counters
Unit: 0 Slice: 0
| Output Pool-Group drops |
| Drop-PG No-drop CPU--PG LCPU-PG RCPU-PG SPAN-PG |
Occupancy drops 0 0 0 0 0 0 |
AQM drops 0 0 N/A N/A N/A N/A |
| Output UC Pool counters |
| Pool 0 Pool 1 Pool 2 Pool 3 Pool 4 Pool 5 Pool 6 Pool 7 |
Dynamic Threshold (cells) 93804 93804 93804 93804 93804 93804 93804 93804 |
Occupancy drops 0 0 0 0 0 0 0 0 |
AQM drops 0 0 0 0 0 0 0 0 |
| Output MC Pool counters |
Dynamic Threshold (desc) 93804 93804 93804 93804 93804 93804 93804 93804 |
Dynamic Threshold (inq thr) 64035 64035 64035 64035 64035 64035 64035 64035 |
| Additional counters |
MEM cell drop reason : 0
MEM descriptor drop reason : 0
OPG cell drop reason : 0
OPG descriptor drop reason : 0
OPG CPU cell drop reason : 0
OPG CPU descriptor drop reason : 0
OPG SPAN cell drop reason : 2815
OPG SPAN descriptor drop reason : 0
OPOOL cell drop reason : 0
OPOOL descriptor drop reason : 0
UC OQUEUE cell drop reason : 0
MC OQUEUE cell drop reason : 0
OQUEUE descriptor drop reason : 0
MC OPOOL cell drop reason : 0
FWD DROP : 642073119
SOD : 0
BMM BP : 0
No Drop : 0
Packets received : 90816417627
TRUNC MTU : 0
TRUNK BMM BP : 0
VOQFC messages sent : 0
SOD messages sent : 0
SPAN desciptor drop : 0
module-1#
Thank You
did you check the MTU in both link ?
MHM
