03-13-2013 08:38 PM - edited 03-07-2019 12:13 PM
The router 1841 is connected directly to the layer switch. the network diagram is below:
Office A --> Switch (L3) --> Router 1841 --> Internet --> Office B
However, when I transfer the file from Office A to office B, the speed very slow ( only around 40 kb/second), and there are an input error and CRC error:
Cisco-R1841#sh interfaces FA0/1
FastEthernet0/1 is up, line protocol is up
Hardware is Gt96k FE, address is 0019.e02f.03dd (bia 0019.e02f.03dd)
Internet address is 10.16.0.2/24
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 251/255, txload 13/255, rxload 4/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:21:30
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1937000 bits/sec, 535 packets/sec
5 minute output rate 5312000 bits/sec, 618 packets/sec
685090 packets input, 275553667 bytes
Received 14382 broadcasts, 0 runts, 0 giants, 0 throttles
22377 input errors, 22377 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog
813755 packets output, 913977385 bytes, 0 underruns
0 lost carrier, 0 no carrier
I have configured the port speed on the switch to 100 MB full duplex, and also changed new network cable. But the file transfer speed still very slow.
Please advice me any solution.
03-13-2013 08:52 PM
reliability 251/255, txload 13/255, rxload 4/255You've got a layer 1 problem. Check and replace the cable.
03-13-2013 08:58 PM
Kindly try changing the port on the switch?
Check the cable again?
Check the NIC driver on your machine is having latest driver install.
Check if possible connecting different laptop?
Inayath
03-13-2013 09:00 PM
After I change the speed on the router to Auto, the problem has been solved. Thanks
03-13-2013 09:06 PM
Ok, but you still have a potential Layer 1 issue.
03-13-2013 11:28 PM
Check Cable
Hardcore Settings Between Two Devices like
Duplex Full
Speed 100
