Routing from g0/0 to g0/1 for cisco 1941
phuayhow01
Hi All,
     I am new to the routing configuration. Below is the setup diagram:
                                   PC1 (10.10.10.4)
                                  (g0/0 - 10.10.10.1)
                                       Cisco 1941
                                 (g0/1 - 192.168.5.87)
                                   PC2 (192.168.5.88)
     What i am trying to achieve here is that PC1 could access to PC2's shared folder.
     Below is my router configuration:
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.10.10.1 255.255.255.248
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 192.168.5.87 255.255.255.0
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 101 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.5.88
access-list 23 permit 10.10.10.0 0.0.0.7
     Could anyone enlighten me what go wrong?
Thank and Regards
Raymond
3 Accepted Solutions
You need to overload g0/1 interface - external interface.
ip nat inside source list 101 interface GigabitEthernet0/1 overload
2)
You need to make access-list 101 and add there IP, that you need to NAT.
access-list 101 permit ip host 10.10.10.4 any
no ip nat inside
duplex auto
speed auto
no ip nat outside
duplex auto
speed auto
ip http server
no ip nat inside source list 101 interface GigabitEthernet0/0 overload
no ip route 0.0.0.0 0.0.0.0 192.168.5.88
ip routing
no access-list 23 permit 10.10.10.0 0.0.0.7
Why u need Nat Inside Outside you can achieve this using sample config that i have done.
Jawad
Looks like at PC1 you have got mask 255.255.255.0.
Network mask at PC and router must be the same.
So if you change at router mask to 248 and at PC to 248 - all should work as well.
And, if you do not need network address translation, better do not use it and use recommendations that Jawad Mukhtar told you.
7 Replies 7
1)
2)
no ip nat inside
duplex auto
speed auto
no ip nat outside
duplex auto
speed auto
ip http server
ip routing
Jawad
Good day Jawad Mukhtar,
          Really appreciate your reply.
          I have tried your method and it still cannot. Do i need to input the default gateway for PC1 to 10.10.10.1 and PC2 to 192.168.5.87? When i use PC1 to ping 192.168.5.87 or 192.168.5.88, it always indicated "request  timed out".
                       PC1 (10.10.10.4)(Default gateway - 10.10.10.1)
                                  (g0/0 - 10.10.10.1)
                                       Cisco 1941
                       PC2 (192.168.5.88) (Default gateway - 192.168.5.87)
Below is the full detail of  router 1941configuration:
Current configuration : 3352 bytes
! Last configuration change at 02:09:09 UTC Wed Mar 13 2013 by cisco
! NVRAM config last updated at 02:04:58 UTC Wed Mar 13 2013 by cisco
version 15.1
service password-encryption
hostname Pioneer
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip domain name yourdomain.com
crypto pki trustpoint TP-self-signed-625968446
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-625968446
revocation-check none
rsakeypair TP-self-signed-625968446
crypto pki certificate chain TP-self-signed-625968446
certificate self-signed 01
  30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  34343630 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  9F4C591D AC9DA311 042AD539 6652C6C3 67C15E19 2DFF7527 B46474A9 4ADA8DC9
username cisco secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
duplex auto
speed auto
duplex auto
speed auto
ip http server
control-plane
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
One more thing is that even i key in
                                                       router# ip routing followed by "Enter" key
I cannot see the ip routing inside my configuration.
Hope to see your reply soon.
Thank and Regard,
Raymond
Good day Alexander Miyar,
    Thank for your reply.
                                  (g0/0 - 10.10.10.1)
                                       Cisco 1941
Current configuration : 4328 bytes
! Last configuration change at 02:32:29 UTC Wed Mar 13 2013 by cisco
version 15.1
hostname Pioneer
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef-
  69666963 6174652D 36323539 36383434 36301E17 0D313231 31323830 36313231
  D7F57FDE 1F4FA2DE 3A206C2D 2A9338D0 254B1E72 E98DB6DE BC5B652E B8D0B0DB
redundancy
no ip address
shutdown
ip nat inside
duplex auto
speed auto
ip nat outside
            duplex auto
speed auto
ip http server
control-plane
line con 0
     login local
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
line vty 5 15
access-class 23 in
privilege level 15
login local
end
          Hope to hear from you soon.
Thank and Regards,
Raymond
phuayhow01
Hi Alexander Miyar and Jawad Mukhtar,
        I have solved my problem already. I do not know why it is so. I just change my subnet for g0/0 from 255.255.255.248 to 255.255.255.0, i could ping and access PC2 from PC1. I used both of the method and it worked fine.
       If you could explain why, it would be nice.
Thank and Regards,
Raymond
Hi Alexander Milyar,
      Thank for your explanation.
Raymond
