Input error in 2960 switch
prince.p
How to troubleshoot input error in Cisco 2960 switch below is the input error detail
GigabitEthernet0/23 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 3cce.7345.b497 (bia 3cce.7345.b497)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:17, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 26000 bits/sec, 26 packets/sec
  5 minute output rate 258000 bits/sec, 33 packets/sec
     3507384785 packets input, 754174825899 bytes, 0 no buffer
     Received 69228830 broadcasts (51534310 multicasts)
     0 runts, 436 giants, 0 throttles
     7 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 51534310 multicast, 0 pause input
     5982495711 packets output, 6936042715804 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
Reza Sharifi
Is this the only port with this issue?
Have you tried a different port?
Have you cleared the counters?
Are the counters increasing?
7 Replies 7
Reza Sharifi
clear counters interface x/x
can you help me to identify the issue, why i  get an input error in switch
can you confirm, where this port is connected.
Errors could be due to duplex mismatch
other end of the port is connected with Aruba access point
There multiple possibility for errors on port.
1. Port issue- to identify, try to connect cable to different port.
2. duplex issue:- confirm with duplex setting at aruba access point.
Please rate the post if it useful
prince.p
some of the port is haveing input error issue. i dont know how to clear the count
