input errors on cisco router
Hello guys!
I hope that all of you are well and safe in this crazy time.
Is it this errors  problem or not and how to fix it
Thank you in advance.
FastEthernet0/0 is up, line protocol is up
Hardware is AmdFE, address is 000e.837a.8f80 (bia 000e.837a.8f80)
Internet address is 192.168.0.49/24
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:02, output 00:00:02, output hang never
Last clearing of "show interface" counters 01:21:22
Queueing strategy: fifo
Output queue :0/40 (size/max)
7813 packets input, 10090576 bytes
Received 812 broadcasts, 0 runts, 0 giants, 0 throttles
15 input errors, 0 CRC, 0 frame, 7 overrun, 8 ignored
0 watchdog
2857 packets output, 278195 bytes, 0 underruns
0 lost carrier, 0 no carrier
2 Accepted Solutions
Mark Elsen
 - Check if this thread can help you :
           https://community.cisco.com/t5/small-business-routers/interface-input-errors/td-p/2964643
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Leo Laohoo
Post the complete output to the command "sh run int f 0/0".
It looks like the speed and duplex are hard-coded.  IF this is the case, then the line errors are due to auto-negotiation (or lack of).
Mark Elsen
  M.
Thank you!
Leo Laohoo
Thank you!
