Upgrading Cisco Nexus 3064T from 6.x to 7.x
Andrew White
Level 2
Level 2
I've upgraded many Cisco switches and routers before, but never a Nexus where I have 2 to do.
I've taken a backup and have been given nxos.7.0.3.I4.8a.bin to install.
Can someone help provide the simple steps?
Here is a show version:
Software
BIOS: version 1.6.0
loader: version N/A
kickstart: version 6.0(2)U6(2)
system: version 6.0(2)U6(2)
Power Sequencer Firmware:
Module 1: version v0.0
BIOS compile time: 12/06/2013
kickstart image file is: bootflash:///n3000-uk9-kickstart.6.0.2.U6.2.bin
kickstart compile time: 8/1/2015 0:00:00 [08/01/2015 07:57:50]
system image file is: bootflash:///n3000-uk9.6.0.2.U6.2.bin
system compile time: 8/1/2015 0:00:00 [08/01/2015 08:22:35]
Hardware
cisco Nexus3064T Chassis ("48x10G Base-T + 16x10G/4x40G Supervisor")
Intel(R) Celeron(R) CPU P450 with 3665240 kB of memory.
Processor Board ID FOC19158Z7E
As you can see I've uploaded the new bin file:
NEXUS-01# dir bootflash:
4096 Sep 04 15:42:01 2015 .patch/
0 Jan 21 13:49:10 2019 20190121_134910_poap_3978_init.log
628 Apr 25 19:37:14 2015 license_FOC1910R3AV_15_1.lic
4096 Apr 25 19:49:56 2015 lost+found/
37734400 Apr 25 19:30:24 2015 n3000-uk9-kickstart.6.0.2.U5.1.bin
37853184 Sep 04 15:37:59 2015 n3000-uk9-kickstart.6.0.2.U6.2.bin
189984434 Apr 25 19:30:48 2015 n3000-uk9.6.0.2.U5.1.bin
206750926 Sep 04 15:38:29 2015 n3000-uk9.6.0.2.U6.2.bin
699673088 Jan 25 17:47:10 2019 nxos.7.0.3.I4.8a.bin
1024 Sep 04 15:41:44 2015 sprom_cstruct_2_0_0
1024 Sep 04 15:42:18 2015 sprom_cstruct_3_0_0
99894 Sep 14 16:08:46 2015 syslogd_tmpfile.3526
26120 Sep 25 15:47:00 2015 tftp
4096 Jan 29 19:33:32 2010 vdc_2/
4096 Jan 29 19:33:32 2010 vdc_3/
4096 Jan 29 19:33:32 2010 vdc_4/
4096 Jan 29 19:33:34 2010 virtual-instance/
Usage for bootflash://sup-local
1303400448 bytes used
591769600 bytes free
1895170048 bytes total
NEXUS-01#
Thanks in advance for your time.
Looks fine , just review logs over the first 24hours make sure theres no obvious issues with the new software, in fairness though nx-os is pretty stable
9 Replies 9
marce1000
 - There are no simple steps if you  want to avoid risks. You can avoid that by reading the release notes of the intended version  where you will also find  guidelines and or pointers to upgrade procedure(s).
M.
hI
Its basically the same , just an extra file , theres kickstart and system make sure you have both in place
there is issu but if you can take a hit do as issu faisl a lot
save it check the boot and reload
global boot commands
boot kickstart bootflash:/n5000-uk9-kickstart.7.3.3.N1.1.bin
boot system bootflash:/n5000-uk9.7.3.3.N1.1.bin
# sh boot
Current Boot Variables:
kickstart variable = bootflash:/n5000-uk9-kickstart.7.3.3.N1.1.bin
system variable = bootflash:/n5000-uk9.7.3.3.N1.1.bin
Boot POAP Disabled
Boot Variables on next reload:
Boot POAP Disabled
Sorry about this I've managed to download:
nxos.7.0.3.I4.8b.bin  24-Oct-2018   667.29 MB
But I can't locate the kickstart for this, only n3000-uk9-kickstart.6.0.2.U6.10.bin
If I look under version 7 all I see are python scripts like this:
poap_script_n3k.7.0.3.I2.1.py 4-Sep-2015 0.04 MB
Starting with Release 7.0(3)I2(1) and later releases, there is a single image for booting the Cisco Nexus 3000 Series platforms. The kickstart and system images are not required anymore. The single image binary now boots up on both Cisco Nexus 3000 and 3100 Series platforms and Cisco Nexus 9000 Series platforms. Due to single image binary, the following commands are updated: -
  • boot nxos single_image_binary
  • fast-reload nxos single_image_binary
  • install all nxos single_image_binary
Hi Andrew,
Kick start images no longer needed.
See below:
Note: Beginning with the 7.0(3)I2(1) release, kickstart and system images are no longer used to install the Cisco NX-OS software image on Cisco Nexus 3000 and 3100 Series switches. Instead, a single binary image is used (for example, nxos.7.0.3.I4.1.bin). To install the software, you would use the install all nxos bootflash:nxos.7.0.3.I4.1.bin command.
Link to the release notes:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3000/sw/release/70348b/n3k_70348b_nxos_rn.html
Thanks, how does this look?
Not sure why it says:
Reason: Disruptive upgrade
System version: 6.0(2)U6(2)
Software
BIOS: version 4.0.0
NXOS: version 7.0(3)I4(8a)
BIOS compile time: 12/06/2016
NXOS image file is: bootflash:///nxos.7.0.3.I4.8a.bin
NXOS compile time: 7/5/2018 11:00:00 [07/05/2018 19:57:12]
Hardware
Intel(R) Celeron(R) CPU P4505 @ 1.87GHz with 3903288 kB of memory.
Device name: EMG-LH-LAN-NEXUS-01
bootflash: 1880320 kB
usb1: 0 kB (expansion flash)
Kernel uptime is 0 day(s), 1 hour(s), 40 minute(s), 45 second(s)
Last reset at 943135 usecs after Tue Feb 5 09:45:54 2019
Service:
is just says that because it was hard reloaded and not done through ISSU upgrade whihc can keep the switch up while its done
