Input errors on Switch interface.
Shahab Khan
Community Member
Hi All,
We are getting input error on switch interface connected to Cisco WLC 4404. Interface GigabitEthernet1/2/20 & 2/2/20 are connected to the WLC through a Port-channel 43.
GigabitEthernet1/2/20 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 001c.581b.96b3 (bia 001c.581b.96b3)
  Description: ***connected to WLC gi 1****
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseT
  input flow-control is off, output flow-control is off
  Clock mode is auto
  Last input 00:00:40, output 00:00:00, output hang never
  Last clearing of "show interface" counters 1d19h
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 5311000 bits/sec, 1087 packets/sec
  5 minute output rate 4502000 bits/sec, 934 packets/sec
     31856658 packets input, 16697603991 bytes, 0 no buffer
     Received 109772 broadcasts (98942 multicasts)
     143 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 0 multicast, 0 pause input
     61913072 packets output, 26409857527 bytes, 0 underruns
GigabitEthernet2/2/20 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 001c.58c5.6303 (bia 001c.58c5.6303)
  Description: ***Connected to WLC ***
  Clock mode is auto
  Last input 00:00:45, output 00:00:35, output hang never
  5 minute input rate 1558000 bits/sec, 395 packets/sec
  5 minute output rate 2880000 bits/sec, 1141 packets/sec
     39786901 packets input, 25211217643 bytes, 0 no buffer
     Received 190089 broadcasts (97226 multicasts)
     380 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     105318049 packets output, 25693590410 bytes, 0 underruns
Port-channel43 is up, line protocol is up (connected)
  Hardware is EtherChannel, address is 001c.581b.96b3 (bia 001c.581b.96b3)
  MTU 1500 bytes, BW 2000000 Kbit, DLY 10 usec,
  Full-duplex, 1000Mb/s, media type is unknown
  Members in this channel: Gi1/2/20 Gi2/2/20
  Last input never, output never, output hang never
  5 minute input rate 6897000 bits/sec, 1473 packets/sec
  5 minute output rate 7438000 bits/sec, 2078 packets/sec
     70667118 packets input, 41341807742 bytes, 0 no buffer
     Received 296223 broadcasts (193732 multicasts)
     511 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     164976595 packets output, 51389885464 bytes, 0 underruns
As part of troubleshooting, we replaced both the cables. We also tried changing the ports on switch & WLC both, but the issue still persists.
Shahab
6 Replies 6
Hello
can you post the config intetface config for switch and wlc
res
paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
Sorry to revive this post but I'm trying to not flood the Forum.
I'm having the same problem with my WLC 2504.  All 4 ports are in LAG and there is a high number of input packets with error. However, the wi-fi is still working but quite slow. This input errors could explain the slowness issue??
Here is my Port-Channel configuration:
interface Port-channel1
 switchport access vlan 100
 switchport mode trunk
end
Etherchannel Summary:
Number of channel-groups in use: 2
Number of aggregators:           2
Group  Port-channel  Protocol    Ports
1      Po1(SU)          -        Gi2/0/17(P) Gi2/0/18(P) Gi2/0/19(P)
                                 Gi2/0/20(P)
thanks for the help...
good evening dear
I have the same problem, has anyone seen this?
My switch interface is incrementing input errors, clean but reappear.
I've already changed the interface on the switch, I've changed the optical cord in the SPF, I just haven't changed the gibic yet, is it possible that the problem is in the gibic?
Are there any commands I can validate if this error increment is on the WLC side?
SW-CORE-LIN-01#show interfaces port-channel 28
Port-channel28 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 2416.9d03.3c4c (bia 2416.9d03.3c4c)
Description: ***CONEXAO_WLC_LINHARES***
MTU 1500 bytes, BW 20000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 5/255, rxload 5/255
Full-duplex, 10Gb/s, link type is auto, media type is N/A
input flow-control is on, output flow-control is unsupported
Members in this channel: Twe1/0/44 Twe2/0/44
Last input never, output 00:00:01, output hang never
Last clearing of "show interface" counters 1w5d
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 2643909
5 minute input rate 457039000 bits/sec, 96296 packets/sec
5 minute output rate 446256000 bits/sec, 97326 packets/sec
27364704606 packets input, 19430010143532 bytes, 0 no buffer
Received 1799618 broadcasts (50960 multicasts)
32243 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 50960 multicast, 0 pause input
27913531075 packets output, 19123700090379 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
SW-CORE-LIN-01#
Hello @Carlos Rogério S. Santos ,
how have you configured the port-channel on the switch side ?
on the member links you have channe-group 28 mode on  or channel-group 28 mode active ?
If I remember correctly the first option is the one to be used even if the WLC is declared to be able to support LACP.
the input errors are not classified in any category and are not so many in comparison to total packets received.
32243 input errors
error ratio = 32243 / ( 27364704606 +32243 ) = 1,17 10^-6     just a little more then one packet evey million
this should not cause effects on user traffic.
The input errors might be LACP frames sent by the WLC  ( if so they increase by 2 every 60 seconds)
16120 minutes
last clearing of counters 1w 5d ago --> 17280 minutes
Roughly a possible explanation is that those packets are LACP frames ignored and discarded by the switch if it is in mode on.
Hope to help
Giuseppe
Hello Giuseppe
Thank you very much for the clarification, I help a lot!
One last question, is it possible to force the interface speed on the WLC side to 1000 mbps and also force it to full duplex, instead of leaving automatic negotiation for the two options?
I don't know but auto negotiation is the preferred mode for GE links
Hope to help
Giuseppe
