Devices Isolation
admin-2021
Community Member
We have there devices that we need to isolate them. what is the best way to isolate them from other VLANs.
Suppose that device A,B and C Connected to Vlan1 and we want to allow them connect only to particular Server IP address in Vlan2  which is running in the DMZ.
What is the best way to do isolation? and how?
Best regards,
balaji.bandi
Access Contol List canl help you.
https://www.cbtnuggets.com/blog/certifications/cisco/networking-basics-configuring-extended-access-lists-on-cisco-routers
BB
Mohsin Alam
you can use ACL or VACL depending on your use case.
## Make sure to mark post as helpful, If it resolved your issue. ##
johnlloyd_13
Level 11
Level 11
hi,
you can use private VLANs.
