input errors only on 4500
plavine
I am getting only input errors? What can cause this? I am using nic load balancing across two 4500's could this be an issue?
Here is an example output of sh int
263 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
mchin345
Level 11
Level 11
Make sure proper settings ( trunk and mode ) enabled between the 4500 switches.
Use Ethernet Configuring and Troubleshooting Ethernet 10/100/1000Mb Half/Full Duplex Auto-Negotiation
http://www.cisco.com/en/US/tech/tk389/tk214/technologies_tech_note09186a0080094781.shtml
how would that affect the switchport a host is plugged into? The trunk port does not have errors on it, ONLY the host ports.
