Input errors trunk interface catalyst 4500
alfonso.cornejo
Level 5
Level 5
Hi to all!
I'm having alot of input errors in a Gigabit interface of a catalyst 4500, it is configured as trunk an connected to a catalyst 2960G, in the interface of the 2960G are not any input errors just in the 4500, we already replace the cable between the devices but the situation remains.
CORE1#sh int gi7/45
GigabitEthernet7/45 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet Port, address is 001b.d403.ffcc (bia 001b.d403.ffcc)
  Description: Trunk SERVERS2-2 0/47
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 14/255, rxload 2/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000-TX
  input flow-control is off, output flow-control is off
  Last input 00:00:16, output never, output hang never
  Last clearing of "show interface" counters 4d16h
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 10877000 bits/sec, 2163 packets/sec
  5 minute output rate 56541000 bits/sec, 5627 packets/sec
     953098496 packets input, 1206543544279 bytes, 0 no buffer
     Received 664857 broadcasts (354055 multicast)
     401342 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     477363643 packets output, 169391220601 bytes, 0 underruns
     0 lost carrier, 0 no carrier
Here is the configuration of the two interfaces:
Catalyst 4500
interface GigabitEthernet7/45
description Trunk SERVERS2-2 0/47
switchport mode trunk
logging event link-status
Catalyst 2960
interface GigabitEthernet0/47
description Trunk CORE1 7/45
media-type rj45
Do you have any idea of what could be causing the input errors?
Thanks in advance for your help.
7 Replies 7
Edison Ortiz
You may be running into oversubscribed ports in the 4500. Remember the 6Gbps threshold per module on this chassis.
Have you tried moving this connection to another switchport and/or module and see if you can duplicate it?
__
Edison.
Hi Edison,
I moved it to another switchport but not to another module, I'll try that tomorrow night and see what happen.
I'll post what happen.
I am experinecing the same problem, input errors only on the 4500 side of multiple links to core 6500s. Did you find a resolution to this?
Richard.
Hi Richard,
The problem was that we were over the 6Gbps threshold per module on the 4500, we moved the connection to another module.
Hope this help.
How did you know you were over the 6Gbps threshold are there counters available to show this?
With a sh inter summary and manually add the RXBS and TXBS value from every interface on the module.
jbrenesj
Level 8
Level 8
Quote:
"You may be running into oversubscribed ports in the 4500. Remember the 6Gbps threshold per module on this chassis."
I notice that there are no input/output drops on the interface so I doubt this is an oversubscription case.
What are those input errors??
I bet they are 1504 bytes dot1q frames.
Please paste a:
sh int gi7/45 counters all
