Inquiry About Upgrade Path for Cisco C2960X-48LPS-L Switch
ArjunRajeev
I am preparing to upgrade my Cisco C2960X-48LPS-L switch from the current software version 15.2(2)E5 to the Cisco-recommended version 15.2.7E10 MD.
Could you please advise if I can proceed with this upgrade in a single step, or if there is a specific upgrade path that I should follow?
Thank you for your assistance.
Best regards,
Arjun
7 Replies 7
Leo Laohoo
If the switch is genuine, direct upgrade is fine.
M02@rt37
Hello @ArjunRajeev
Cisco typically ensures compatibility between major software releases, and in this case, you're staying within the same 15.2 train. So, direct upgrade is feasible.
Best regards
DanielP211
I always do direct upgrades with bundle mode on the 2960X.
BR
****Kindly rate all useful posts*****
shambhu.kumar
Please go for direct upgrade. Use this CLI
copy file "c2960x-universalk9-mz.152-7.E10.bin" to switches  (if it is stack copy to all switch and verify md5)
show boot
config t
no boot system
boot system switch all flash:/c2960x-universalk9-mz.152-7.E10.bin
do wr
exit
reload
show boot
show version
Shambhu Kumar
show boot
config t
no boot system
do wr
exit
reload
This is a backward and archaic procedure which I would never recommend to anyone.
Hi Leo,
I’ve been using the above process for upgrades without any issues. Could you please let me know the recommended procedure?
Arjun
show boot
config t
no boot system
do wr
exit
How many command does this process take?
I can summarize all this into one line of command.  ONE.
archive download-sw tftp://<TFTP IP ADDRESS>/filename.tar
This single line of command will do the following:
1.  Extract the BIN file into the flash to all the switch members of the stack.
2.  Change the boot variable string.
3.  Perform a quick MD5 hash check to confirm the BIN file is not corrupt.
