inserting module in an active catalyst 6500
whanson
Level 2
Level 2
I know you can hot swap modules but can you add one to an empty slot while the supervisor is active as long as the module is supported.
Mark Yeates
Level 7
Level 7
Yes you can.
HTH,
Mark
Leo Laohoo
I agree with Mark. The 6500 network modules are hot-swappable. If no activity is observed in the first 5-15 seconds, make sure "power module " is enabled.
