Installation time of NPE-G2= 7200 series NPE-G2 engine with 3 GE/FE/E ports, SPARE
jacinto1m
Can anybody give me a rough idea of what the installation time for the Network Processor engine is:
NPE-G2=7200 series   NPE-G2 engine with 3 GE/FE/E ports
Do you reckon it can be done in two hours?
Any help is much appreciated!
Reza Sharifi
The hardware installation should not take more then an hour.  You also need about 2 to 3 hours to move the config over from the old to the new one, test it and make sure connectivity is there.  So 4 hours should be enough for all of it.
Please remember to tag your threads and help support "Teachers without Borders"
https://supportforums.cisco.com/community/netpro/idea-center/communityhelpingcommunity
