installing a ios on cisco switch 3550
madjass84
                   hi,
     im trying to install a ios 12.2v on my switch. when the screen prompt it does not show me the user move symbol " SW1> ". all i see is " SW:" and from there i can not enter the commands to download from tftp server !!!!!!!!!!
any help please
7 Replies 7
Reza Sharifi
Can you enter any command?
for example, when you are at the prompt, can you issue "sh ver" or "config t" etc...?
hi,
if you type " ? " you can see the commands that you can type, but there is no show ver. if you want to see the version u only can type "version" not like if it is on user mode
Can you post the output of version?
this is what i get when i typed the command version.
    switch : version
c3550 boot loader version 12.1<12r>EA1.  "
Ok, can you do a "dir" and see what image is on the flash
and then
try this
boot flash
save and reboot:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.2_25_see/command/reference/bootldr.html#wp1014755
i saw that but i had doudts wether or not i would have to use the tftp server (winagent) to download the image file and i could not figure out which command to use.
do you have any IOS image on the flash currently?
