PoE - switches and modules support
guillermo.ruiz
Some knows where can I find a document or information about which Switches and Modules currently support PoE?
I found this document:
http://www.cisco.com/warp/public/cc/pd/si/casi/ca6000/prodlit/psnap_br.pdf
but this is just a general information and I need something more complete.
Some help?
I'd really apreciate it.
guruiz
Reza Sharifi
Almost all switches except the Nexus line support POE.
What specific product are you looking for?
Hi Reza,
Thanks for your reply.
In fact, that is exactly what I am looking for. A document, a table or a information where I can review which switches model and modules can support PoE at present.
guruiz
Hi Guruiz,
I have not seen a document that talks about all switches and all the POE modules for them.  You may have to go through each specific product data sheet to get all the details you need.  I know that 2900, 3560, 3750, 4500, 6500, 2900 and 3900 routers with switch module all support POE line cards.
You need to look at the specific switch that you have as you can get switches without poe on them.  All of the above switches that Reza mentioned have both POE and non-POE types.
