Instead of VTP , what protocol can be used for non Cisco switches?
krahulbgp
 VTP (Virtual Tunnel Protocol) is Cisco proprietary but later on IEEE develop the 802.1Q which have the same functionality. If you whant check the device support trunk, you need to look at 802.1Q support.  Then, you need to look at vendor documentation to see  how they implement 802.1Q on their switches.
balaji.bandi
Not Much Familiar deployment as i am aware of this industry  if the Multi vendor  you need to look below :  MVRP
https://en.wikipedia.org/wiki/Multiple_Registration_Protocol#Multiple_VLAN_Registration_Protocol_.28MVRP.29
there is some Limitation cisco mentioned - iam sure you aware already in the research.
https://www.cisco.com/c/en/us/td/docs/ios/lanswitch/configuration/guide/lsw_cfg_mvrp.html#wp1068279
This where automation comes in picture....populate the information across board ?
BB
