Inter-vlan communication on single switchport between access and voice vlan?
Is there a way to enable communication between the access and voice vlan on a single switchport on a 3750E running 15.0? New phones are talking up a layer-2 stack to their gateway, circling around to the workstations gateway, and then back down a L2 stack to the appropriate workstation. Is there a way to knock out this wacky and extensive L2 path I have going and just enable communication between the access and voice vlan on a per-switchport basis?
Thanks!
Joseph W. Doherty
Not that I'm aware of.
Although data and VoIP VLANs can share a port, they are still different VLANs.  Normally you need to get to a L3 gateway.
At L2, you could interconnect the two VLANs via two other access ports, although that's negates the reason why we normally have them in different VLANs.
L2 transfer should be per stack member whereas L3 transfer is via the stack master.
